Can't post video here of it but music is played on high spec machine reading off an evo 970 drive with stems pre computed, but they just keep skipping pausing? Happy to email a video
geposted Thu 08 Apr 21 @ 1:37 pm
What's your skin fps set to?
geposted Thu 08 Apr 21 @ 2:50 pm
Skin FPS is set to 30fps in options
geposted Thu 08 Apr 21 @ 3:04 pm
Try a higher number like 60. I had jumping with 30 and it went away instantly once increased.
geposted Thu 08 Apr 21 @ 4:10 pm
OK will try that thanks
geposted Thu 08 Apr 21 @ 4:11 pm
Ok tried that but still jump, not sure what else i can try.
Could it be video card related although i do have a Radeon RX 570 ARMOR 8GB OC GDDR5 Graphics Card so should handle it ok, if it doesn't my laptop stands no chance
geposted Fri 09 Apr 21 @ 3:49 pm
If your cpu has graphics too you could see if useHighPowerGPU setting to either high or low power makes a difference
geposted Fri 09 Apr 21 @ 4:33 pm
where is that setting looking can't see it
geposted Fri 09 Apr 21 @ 4:38 pm
set useLowPowerGPU to high power it is on default
geposted Fri 09 Apr 21 @ 4:39 pm
