Topic: Booth settings
Hi I have a Denon MC 6000 MK2 I would like to use the booth I am getting music through the system but unfortunately the mic is not coming through in the settings of Virtual DJ booth is tick on please can someone advise me much appreciated
I would like the music and the mic to come through the booth speakers
geposted Thu 08 Apr 21 @ 2:47 pm
are you routing mic into vdj with audio config?
Hi thank you I have got the mic plugged into the mixer Deano MC6000MK2 in mic 1 and the audio settings booth microphone in Virtual DJ is ticked yes
The "Booth" output of MC6000MK2 is a hardware function.
VirtualDJ cannot access that output and does not send sound on it.
Also by default, VirtualDJ does not receive the sound of the MIC either
Take a look at this:
https://www.virtualdj.com/manuals/hardware/denon/mc6000mkii/layout/master.html
Normally, if you switch knob 52 on MST position, MC6000MK2 should output on Booth output whatever is sending on Master output.
Also if you want, you can route the sound of the mic on software, but still that won't give you any access over booth output
Thank you I will have a look and I’ll give this a try and come back to you if you don’t mind
