I use my VDJ for karaoke. Just recently and randomly while playing a karaoke song there’s a slight electronic sound and then it freezes and then continues to play. This only happens randomly and I can’t understand why. Does anybody have an idea why is this happening?
geposted Thu 08 Apr 21 @ 10:18 pm
Could be the audio buffer running dry on your sound card.
Try set a bit higher buffer on the driver (latency)
256 or 512 samples should be ok for most computers
(alternatively set same under latency in VirtualDJ settings, if mac or not using a Windows driver with buffer settings)
geposted Thu 08 Apr 21 @ 11:22 pm
Thanks I’ll look into it!
geposted Thu 08 Apr 21 @ 11:27 pm
