Topic: Drum fills with loop roll [idle chat]
I put this in another thread, but don't think op cares to try it.
I want to keep tinkering, if I can knock up 8 or so, there's a padpage/ maybe a plugin that could be made.
So I'm after ideas & thoughts on it,
describe in plain English or even knock up a video of you mashing the loop buttons.
I'm still experimenting and the timing can be tightened up.
try these couple on a custom button
glitchy buildup [try 8 before the drop]
set 'stage' 0 & set 'org' `get_beatpos` & effect_beats 'loop roll' 4 & effect_active 'loop roll' & repeat_start_instant 'test' 25ms &
var 'stage' 0 ? param_bigger "get_var 'org' & param_add 4" "get_beatpos" ? effect_beats 'loop roll' 2 & set 'stage' +1 : nothing :
var 'stage' 1 ? param_bigger "get_var 'org' & param_add 8" "get_beatpos" ? effect_beats 'loop roll' 1 & set 'stage' +1 & effect_active 'loop roll' & effect_active 'loop roll' & goto -8 : nothing :
var 'stage' 2 ? param_bigger "get_var 'org' & param_add 3" "get_beatpos" ? effect_beats 'loop roll' 0.75 & set 'stage' +1 & effect_active 'loop roll' & effect_active 'loop roll' : nothing :
var 'stage' 3 ? param_bigger "get_var 'org' & param_add 5" "get_beatpos" ? effect_beats 'loop roll' -1 & set 'stage' +1 & effect_active 'loop roll' & effect_active 'loop roll' : nothing :
var 'stage' 4 ? param_bigger "get_var 'org' & param_add 7" "get_beatpos" ? effect_beats 'loop roll' -1 & set 'stage' +1 & effect_active 'loop roll' & effect_active 'loop roll' : nothing :
var 'stage' 5 ? param_bigger "get_var 'org' & param_add 8" "get_beatpos" ? effect_active 'loop roll' off & repeat_stop 'test' & set 'stage' 0 : nothing : nothing
playing with triples, moving position, and dump, why not?
goto +4 & set 'stage' 0 & set 'org' `get_beatpos` & effect_beats 'loop roll' 4 & effect_active 'loop roll' & repeat_start_instant 'test' 25ms &
var 'stage' 0 ? param_bigger "get_var 'org' & param_add 4" "get_beatpos" ? effect_beats 'loop roll' 0.33 & set 'stage' +1 : nothing :
var 'stage' 1 ? param_bigger "get_var 'org' & param_add 5" "get_beatpos" ? effect_beats 'loop roll' 0.33 & set 'stage' +1 & effect_active 'loop roll' & goto -4 & effect_active 'loop roll' & : nothing :
var 'stage' 2 ? param_bigger "get_var 'org' & param_add 2" "get_beatpos" ? effect_beats 'loop roll' 0.33 & set 'stage' +1 & effect_active 'loop roll' & effect_active 'loop roll' : nothing :
var 'stage' 3 ? param_bigger "get_var 'org' & param_add 3" "get_beatpos" ? effect_beats 'loop roll' 1 & set 'stage' +1 & effect_active 'loop roll' & effect_active 'loop roll' & goto +1 & dump : nothing :
var 'stage' 4 ? param_smaller "get_var 'org' & param_add 3" "get_beatpos" ? effect_active 'loop roll' off & repeat_stop 'test' & set 'stage' 0 & dump & goto -1 : nothing : nothing
geposted Sat 10 Apr 21 @ 7:27 pm
