How do you set hot cues in VD 2021?
It is not on the deck like in my previous version.
Thanks.
Thanks.
geposted Sat 10 Apr 21 @ 9:35 pm
best guess from me is you need to look at padpages, because maybe you've moved from a 8.1 skin to the 8.5 skin, but that's a guess from me as you haven't give much detail, [setting hotcues, nothing much has changed for a few years].
geposted Sat 10 Apr 21 @ 10:08 pm
As mentioned you find hotcues at the pads
https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html
As well as in the hot cue section (Pro/Performance skin)
https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/custombuttons.html#panel
geposted Sat 10 Apr 21 @ 10:34 pm
