Topic: HELP WITH CUE
djbaum81PRO SubscriberMember since 2012
So i have cue installed on my backup laptop. They are doing away with cue and all the support. When i go to update to the new VDJ it says it isnt compatible with my processor. Any ideas?
geposted Mon 12 Apr 21 @ 2:43 pm
what processor do you have?
geposted Mon 12 Apr 21 @ 2:49 pm
Would probably be a good idea to tell us what your processor is and where exactly you get the error message?
geposted Mon 12 Apr 21 @ 2:50 pm
geposted Mon 12 Apr 21 @ 3:00 pm
When you have updated, you might have to copy over a few things from the CUE directory to VirutalDJ directory (they dont use same folder in /documents/)
But just post when you are ready and have updated Windows ... if that was it
geposted Mon 12 Apr 21 @ 4:19 pm
