i saw BUILD 6404 in early changelog, is that mean i can export my music from vdj to usb stick?
working on cdj and other XDJ series?
geposted Mon 12 Apr 21 @ 2:52 pm
yes ;-) works for both ..
geposted Mon 12 Apr 21 @ 2:58 pm
OMG VDJ U GUYS ROCK! keep making amazing stuff!
geposted Mon 12 Apr 21 @ 3:02 pm
How do we use this new stuff then? Any instructions?
geposted Mon 12 Apr 21 @ 3:14 pm
will come, its not out in Public version yet
That being said its just a folder called "CDJ Export" where you can drag and drop songs to usb sticks, and create playlists.. easy to use.
geposted Mon 12 Apr 21 @ 3:20 pm
Yes I understand it's an early access release - but we still need to know how to use any new features added.
I see the folder now, since you provided the info. Thanks!
Any info on the other new additions - hashtags, quick filters and colour filters?
geposted Mon 12 Apr 21 @ 3:49 pm
As above, you guys keep releasing new features pre-release so we can test, but how can we test if there are no instructions for the features?
This has bugged me for years now. We're not all privy to the the development and beta versions.
geposted Mon 12 Apr 21 @ 4:02 pm
Should be all in the manual asap, so wont be much later than EA, and before PA for sure
geposted Mon 12 Apr 21 @ 4:17 pm
The colour rules will I think make many people happy, if it allows tracks to be listed in a different colour once they've been played.
Assigning colours to tracks based on certain criteria (i.e. make all reggae tracks green) is a long standing request of mine.
Hopefully it has some intelligence behind it, so it can check if a user has already assigned a colour to something etc.
geposted Mon 12 Apr 21 @ 4:40 pm
Hmm... I'm not sure I would get a single green song in my database :-D
(reggae is not big in Northern Europe)
geposted Mon 12 Apr 21 @ 5:48 pm
