Hello Everyone,
I hope everything fine with you.
I have a question.
During Mixing, How do I setting for All Volume Automatically Same Level ?
Due to some music are level are bit low. some music are remastered, sound high,
I would like to setting all volume are same volume level during mixing,
I really appreciate If you could answer my question !!
I look forward to hearing from you soon.
I have a question.
geposted Wed 14 Apr 21 @ 12:09 pm
AutoGain in settings is made to do just that .. play all songs at same level.
But as you say, remastered tracks are sometimes "compressed" where all of the song is almost full peak volume (often dubbed "loudness war"). https://en.wikipedia.org/wiki/Loudness_war
They might be perceived as louder than say a high dynamic range song that has "real" low and highs..
Not sure if there is any "easy fix" for that other than manually adjusting volume / gain a little bit.
Or using a VST compressor and just compress everything ... (but probably wont be so nice ... hehe)
geposted Wed 14 Apr 21 @ 12:29 pm
Hello Rune I really appreciate your answer !! I will try to setting !!
Thanks a million !!
Thanks a million !!
geposted Wed 14 Apr 21 @ 12:31 pm
