with EA 6404, the added hashtag searching drop down in the Info Panel when in edit mode, behaves differently for Genre vs User 1(2) fields.
From the drop down for Genre > Edit one sees this
a way to type a NEW Genre, or choose from an existing Genre.
From the drop down for User1 > Edit one sees this:
All one can do from the Edit menu is to change Column name, from User 1, to say User 3 or something else.
I would have expected maybe, that in Edit menu, would allow one, to ADD, and/or select, a new hashtag. (as one can do for Genre)
IE) NOT a way to create a New Hashtag or select an existing Hashtag from the edit menu.
PS
And then if one, changes Column Name to User 3 when in Edit, and checks the QuickFilter button, checkbox, the Button name at the top of the browser does NOT change to User 3, it remains unchanged, as User 1. Only the "Field Name" in the Info Panel changes to User 3
PS
geposted Fri 16 Apr 21 @ 6:07 am
Instead of Edit, select "Add new tag"
And yes, it's meant to be different behavior since User1/User2 fields (aka Hashtags from now on) are going to host a hole new level of functionality
geposted Fri 16 Apr 21 @ 6:42 am
Thank you Phantom
Looking forward to the new features in VDJ.
LOVE VDJ !!
LOVE VDJ !!
geposted Fri 16 Apr 21 @ 6:58 am
You can just type in the list of hash tags to remove/edit or add them
geposted Fri 16 Apr 21 @ 7:00 am
Did not realize that was possible, and see now that the Edit can be used to modify existing Hashtags. And so simple. Awesome !!
Thank you Adion
geposted Fri 16 Apr 21 @ 7:12 am
