Want to program a Button that sets a (normal) loop when pressed briefly.
Same button shall set a (back) loop when pressed longer to save buttons on my Launchpad .
BUT: this back-loop should be set exactly when the button is released.
So I tried:
[ holding ? loop_back on & up ? loop 8 : nothing : loop_back off & loop 8]
what may be the mistake in the script?
Thanks again in advance
So I tried:
geposted Fri 16 Apr 21 @ 8:40 pm
holding 300ms ? loop_back on & loop 8 : loop_back off & loop 8
If I understod you correctly .. .can adjust the ms value to fit your need (or remove the ms value for default 500ms)
geposted Fri 16 Apr 21 @ 9:04 pm
sorry Rune, but that would be too easy.
With Your line the back-loop starts after 300 (or whatever) ms during I press the key.
I need that it starts exactly when I release the button.
So that I can set the point of loop exactly...
geposted Sat 17 Apr 21 @ 12:14 pm
True, but thats how your original example was, so thought you didnt mind that.. .
If you want something instant, "holding" probably is not the way to go... since you mean to have a long press to decide if the loop is forward and backwards, and that imply time to decide what to happen, and will not be instant (the loop direction cant change after loop has started)
Using "up" can not be combined with holding. Holding queries up on its own .. if up is after X ms.
Sometimes less is more, make it easy
A key combo will work fine for example
Button 1 : shift
Button 2 : shift ? loop_back on & loop 8 : loop_back off & loop 8
Button 1 : shift
geposted Sat 17 Apr 21 @ 12:24 pm
you can't combine key lookups (up down holding repeat) so have to emulate
loop_back off & up ? repeat_stop hld & loop 8 : repeat_start hld 500ms 1 & loop_back on
geposted Sat 17 Apr 21 @ 12:40 pm
Thank You both so much! You made my day!
And cause of this kinda "action on release" it was hard to set the loop during playback in time.
So I had to put a "loop_move -50ms" inside:
[ loop_back off & up ? repeat_stop hld & loop 4 & loop_move -50ms : repeat_start hld 400ms 1 & loop_back on]
And that leads me to the next question:
(sorry, hope not to bore you)
Is it possible to let vdj automaticly adjust the start of a loop on the nearest beatgrid point?
( I think I remember some such thread, but unfortunately I can't find it.)
geposted Sat 17 Apr 21 @ 6:36 pm
Turn on quantize loop in the loop settings
geposted Sat 17 Apr 21 @ 6:44 pm
and also have quantize value at 1 beat
geposted Sat 17 Apr 21 @ 7:31 pm
Great! Thanks for the quick help.
And just for completeness: With the QUANTIZE option the "loop_move -...ms" isn´t needed any more.
geposted Sat 17 Apr 21 @ 8:47 pm
