Hi
Currently the FX dry/wet knob on the right side of the Prime 4 is mapped to select a video effect, with the buttons below turning the effect on/off and opening/closing the GUI.
Mostly I have the camera turned on in the master video slot, so I can turn the camera on/off using the 'beats -' button......... but when I turn the dry/wet knob to try and access one of the 'transforms', it turns the camera off.
I want to be able to leave the camera on, but access (e.g.) the 'colorize' transform and apply that to the camera feed.
I can do that on the skin via the drop down menu. The camera remains on when I select 'colorize' and the effect is applied to the camera. I'd just like to do the same from the controller.
Can the mapping be modified to allow the camera to remain on when the FX dry/wet knob is turned?
geposted Sat 17 Apr 21 @ 11:01 am
Map the FX BEATS encoder as ..
This will allow you to select a different Video FX without disabling the previous one.
device_side 'left' ? video_transition_select : deck master effect_select_multi 'video'
geposted Tue 20 Apr 21 @ 3:51 am
Thanks Babis :-)
geposted Tue 20 Apr 21 @ 4:24 pm
