Music/iTunes/iTunes Library.xml
that is where VDJ thinks the music library is. However Big Sir does not use iTunes Library.xml it is using Music Library.musiclibrary. Tried to change search path but VDJ grey that out.
Any suggestions?
Any suggestions?
geposted Sun 18 Apr 21 @ 3:02 am
On Big Sur VirtualDJ does not use the xml, but it uses the Music API directly to request the list of playlists and songs.
It should therefore reflect whatever you see in the Music app.
geposted Sun 18 Apr 21 @ 6:23 am
