The old a song, I ripped from CD is very low Level of Volume,
I would like to remaster this MP3 song more level up Volume,
However, When I launch Virtual DJ, Sound Volume Level shows already 100 %,
I mean full up, This may silly question, but I would like to re-record some more Volume up.
How can I re-record some more Volume up ?
I really appreciate If someone could answer my question.
Thank you very much. :)
geposted Tue 20 Apr 21 @ 6:21 am
Just record it
It's most likely your autogain that brings the volume up
So if you record it in VDJ it will stay up - depending on how loud your general recording volume is of course, which will depend on your general zeroDB setting
But I would never do that - it's too slow and too much work. You can avoid re-recording the track by simply changing it's gain in something like audacity or maybe the really old mp3gain
geposted Tue 20 Apr 21 @ 7:45 am
I really appreciate your help. I will try to do that !! Thank you very much !!
geposted Tue 20 Apr 21 @ 10:29 am
