How do you export a playlist as a .M3U or .XML?
geposted Tue 20 Apr 21 @ 9:00 pm
just create one and save it from sidelist
VDJ playlists in \VirtualDJ\Playlists are already m3U
geposted Tue 20 Apr 21 @ 9:08 pm
OK, and where can I find the m3u file?
geposted Tue 20 Apr 21 @ 9:19 pm
If you dont mean just copy a m3u file, but rather export the music as well?
Simply right-click the playlist, and choose "Export to..." .
And VirtualDJ will make copy of the playlist with the content (music) on that location (for example usb stick)
geposted Tue 20 Apr 21 @ 9:31 pm
But since you mention XML perhaps you just want to use the tracklist externally?
If so, open the playlists you want to export.
Then at the small dot at far left browser toolbar, choose "Export Browser View".
You can choose between CVS and HTML format (CVS can be imported into spreadsheets etc)
geposted Tue 20 Apr 21 @ 9:33 pm
OK, thank you. :)
geposted Tue 20 Apr 21 @ 10:35 pm
