I have my own stream....my own website.......and i have several shows.....
I spin at 2 radio stations....
I would like to be able to to stream to both stations at the same time......
One stations stream runs on shoutcast........the other one runs on icecast.......and theres not another space available to add a 2nd stream on VDJ.....
Can anyone help me ?
geposted Wed 21 Apr 21 @ 9:39 am
Its not possible to do that... at least not currently.
You can record and broadcast at same time, or video broadcast and radio broadcast at same time.
But can not do two same broadcasts simultaneously..
What you can do though, is use a second computer, and wire the audio output from first computer to line in at 2nd computer. And set that computer to broadcast from the line in (record entry)
https://www.virtualdj.com/manuals/virtualdj/settings/audiosetup/recordloopback.html
geposted Wed 21 Apr 21 @ 11:18 am
MUCH GRATITUDE !!!!
Im gonna try it.....
THX AGAIN !!!
THX AGAIN !!!
geposted Thu 22 Apr 21 @ 6:52 am
Will work fine ;-)
The only "drawback" is perhaps that only one of the computers are directly broadcasting, so the 2nd computer broadcasting from line-in will not send track titles..
But not sure if that matters or not...
geposted Thu 22 Apr 21 @ 10:49 am
I remember reading Restream, Boxcast, and a few others who could do Simulcasting.
geposted Thu 22 Apr 21 @ 11:28 am
that also works, if not wanting to "restream" with a 2nd computer, you can use online services
(but they usually cost a little bit to use though)
geposted Thu 22 Apr 21 @ 11:31 am
Yes.....they do cost........
but to let u know......the song titles arent important.....
im just glad that both pc's can both stream with no issues.....
thanks again bro.......u saved me a lot of grief , time and money.........
geposted Thu 22 Apr 21 @ 12:52 pm
Panther check your Inbox, messages ... I sent you a PM, the other day.
geposted Fri 23 Apr 21 @ 5:14 am
With the butt app and a loop back cable can be done on one computer.
Of course this is for audio only.
geposted Fri 23 Apr 21 @ 4:53 pm
