ok i searched and tried to find a solution but to no avail anyway im not good at re mapping but heres what i want to do i have a rane one and i want to use the tap button since it has no use in vdj i want it to basically cycle through all the color fx when i hit the buttton and use the filter knob to controll the effect. hopefully im not asking too much for someone to help me
geposted Thu 22 Apr 21 @ 4:45 pm
you can just change the action for that entry in the mapper to :
filter_selectcolorfx +1
You could make some deck logic, but perhaps just change all decks.
deck all filter_selectcolorfx +1
If not, it follows "selected deck" (the "working deck", aka "touched"/used last)
geposted Thu 22 Apr 21 @ 5:07 pm
geposted Thu 22 Apr 21 @ 5:14 pm
thank you so much. it worked exactly how i wanted it to work with both changing at the same time
geposted Thu 22 Apr 21 @ 5:31 pm
