Hey everyone,
I'm trying to use VirtualDJ, but the window is completely invisible. It focuses VirtualDJ if I click on open space on my desktop, and my mouse cursor changes accordingly, but I can't see anything. I've tried doing a clean re-install and tried launching using a different user, but I keep getting the same results. I'm using a 2010 MacBook Pro 15" (i7-620M, 8GB, GT330M) running macOS Mojave 10.14.4. Anyone have any answers to this?
Thanks.
Thanks.
geposted Sun 25 Apr 21 @ 6:35 pm
geposted Sun 25 Apr 21 @ 7:06 pm
Can always try this (in case of a bad skin or plugin etc)
- in /documents/virtualdj/ rename settings.xml to something else
- start VirtualDJ.
That way you start with factory default settings
But if you already installed as different users, thats probably not it (should reset screen position though)
- start VirtualDJ.
geposted Sun 25 Apr 21 @ 7:07 pm
I've tried the solutions on the link, and none of them work. As for settings.xml, I've tried deleting the entire /Documents/VirtualDJ/ folder and have had no success.
geposted Sun 25 Apr 21 @ 8:13 pm
If you deleted the whole folder, at least run the installer again, so that the software has what it needs
https://www.virtualdj.com/download/
As for not showing on screen, not sure what that is, but maybe someone with a mac got an idea
geposted Sun 25 Apr 21 @ 8:47 pm
So a few updates. macOS registers that there is a window and the buttons on my controller still work, but there is no GUI whatsoever.
geposted Mon 26 Apr 21 @ 3:12 pm
This is a MacOS problem, not a VirtualDJ problem, hence my post above. If they don't work, I recommend you post a question on that site.
geposted Mon 26 Apr 21 @ 4:44 pm
I've also had this happen when I accidentally minimize the VDJ window (little yellow icon in top left on macOS) OR swtich to another app. *Sometimes* you can get it to reappear by right-clicking the VDJ icon in your dock, and choosing "Show All Windows" and other times....well...I put an on iPod on and restart VDJ. Frustrating.
geposted Tue 27 Apr 21 @ 2:35 am
