I know it’s old but I have a numark DMC2 controller I have been using in my mobile DJ business for years. My Mac had to update and I now need to purchase virtual DJ as the version I have is not supported. My question is will my controller work with the New version of virtual DJ and if not what controller is recommended for a rack mount situation.
geposted Tue 27 Apr 21 @ 8:59 pm
Should work fine ;-) Supported hardware in VirtualDJ
https://www.virtualdj.com/products/hardware.html?model=nmdmc2
(with macOS update, old hardware can stop working.. but sounds like you checked that. Can always download the free installer, and you can test first that way.. https://www.virtualdj.com/download/ )
geposted Tue 27 Apr 21 @ 9:47 pm
