Virtual dj can't open database and it tells me problem opening database. Lost all my cues please help me to fix it and work as 1st.
Thanks
Thanks
geposted Fri 30 Apr 21 @ 3:44 pm
Try restart the computer....
Might just have been a frozen process that had already taken the database
geposted Fri 30 Apr 21 @ 3:46 pm
It comes like import from version 7 and I ignore it after that then it start telling me problem opening database
geposted Fri 30 Apr 21 @ 3:48 pm
Its just asking you to press "FIX" right?
Do that, to fix the database
And if you just imported and something failed, you can always delete the new database (not the old)
And try again
And try again
geposted Fri 30 Apr 21 @ 3:49 pm
1st it tells me to import from v7 and I ignore, after the ignore and it start telling me problem opening database.
I have done the restarting several times but still
geposted Fri 30 Apr 21 @ 3:53 pm
What are you trying to do?
Import v7 database or not import?
And ideally should stop using such a 10 year old software.
Move over to modern VirtualDJ https://www.virtualdj.com/download/
geposted Fri 30 Apr 21 @ 3:56 pm
From previous posts I remember he was using a cracked version of 2020 so not sure why there's sn issue with v7 database.
geposted Fri 30 Apr 21 @ 9:23 pm
I was using numark cue and that database was working on virtual. In the browser option in virtual dj 8, it has import v7 database.
The database am talking is on my external hard drive
geposted Fri 30 Apr 21 @ 11:12 pm
