How can i stop my virtual from freezing can anyone help me with this problem
geposted Sat 01 May 21 @ 2:14 pm
Start by providing enough information for people to determine the cause and offer a solution.
geposted Sat 01 May 21 @ 2:16 pm
If its a low end mac you can try set precomputeStems in settings to "only use precomputed"
And also update macOS to the latest possible for your mac
And any clues to what "type" of freeze? what you do when it happens? using anything particular, audio drop out? interface locks up? during song load? video mixing? etc etc
More clues would be easier to have a guess at what it can be ;-)
geposted Fri 07 May 21 @ 10:39 pm
Hey Guys, got a same issue here: whenever I load a new song, make changes to the interface, open or close settings, change a effect or do a handling to a song, the current playing song freezes for a second.
I'm using a very new macbook pro and quite a fast one too ;-) combined with the Traktor Kontrol S4
Only thing i can't rule out is the interface (USB-C) I use, since don't have another...
thanks for any help you can give me.
geposted Sun 09 May 21 @ 9:39 am
