Topic: Unwanted Added Decks
nowavePRO InfinityMember since 2015
Hi,
I’ve just come across a new problem here and I don’t know what has caused it.
Whenever I’m playing now (I use 2 decks only), if I want to cycle between Deck A and B, pressing tab will also cycle through Deck C and D, even though I don’t have a 4 Deck option on.
Also it appears to load my tracks into them so I’ve ended up pressing play on Deck C during a mix by accident.
Can anyone help me remove these two additional decks for good, please?
I like that there’s the option but I mostly don’t wanna utilise it personally!
Thank you,
Luke
geposted Sun 02 May 21 @ 2:51 pm
How do you know its cycling through C and D?
4 deck skin selected ?
geposted Sun 02 May 21 @ 3:56 pm
So it’s set up as a 2 Deck skin - but if I keep pressing tab, it cycles from A, to B, then the colour either side (highlighting A or B when normally active) will disappear until I press it twice more and it will come back to A.
Also when I press tab after it highlighting Deck B, and then pressed play, it shows a new coloured wave form playing a song up top.
I checked to see if these colours match up by choosing a 4 Deck skin briefly and it was correct.
I hope that all makes sense sorry.
So yeah it’s on a 2 Deck skin, but definitely playing 4 decks without me being able to see them or indeed want them active.
geposted Sun 02 May 21 @ 4:02 pm
might be some user created skin then, thats not proper..
Is same happening with default 2 deck skin?
(and you can not have any songs loaded on deck 3 and deck 4 when you try)
Also, a 4 deck controller perhaps?
geposted Sun 02 May 21 @ 4:06 pm
