I have an issue with my denon mc6000 mk2 issues on 1 deck when I use that decks sync button to match the opposite decks BPM. The pitch level jumps to approx 150 bpm. I have replicated this issue using 2 separate PC's with the controller . I have also managed to temporarily fix the issue when I restart the controller. However, it will re-occur when I next connect up the controller to the PC.
geposted Mon 03 May 21 @ 5:30 pm
what bpm are the songs on deck? both sides
Clicking sync will do the "shortest distance" for a match, so that can be double of original bpm, depending on what the 2 songs you are trying to sync area
geposted Mon 03 May 21 @ 7:31 pm
