Attempting to learn more of the amazing features of VDJ.
How and where would effect_colorfx be used, (what does it do) all I can find is
Could you explain 4 custom slots and where they are (or what they represent)?
and similarly effect_stems_color
Can stems be applied to the knob under the EQs with this?
I cannot get them to do anything.
(not in Wiki yet)
Thanks
VDJ v b6418
(not in Wiki yet)
Thanks
VDJ v b6418
geposted Tue 04 May 21 @ 6:15 pm
AFAIK effect_stems_color is not for audio color but button
test with:
effect_stems_color & param_cast & debug
so that this can't be used as an audio effect
The " 4 custom slots" is currently a big unknown !!
test with:
geposted Tue 04 May 21 @ 7:49 pm
The 4 custom slots means that you can use "effect_colorfx 1", "effect_colorfx 2", etc... on 4 different knobs/sliders to have 4 independent color fx.
Since most mixers have just a single filter knob it's probably more practical to stick with the default unless you have knobs to spare on your controller.
You can use effect_stems to select which stem the effects apply to. This is for both the color fx and regular fx.
geposted Tue 04 May 21 @ 7:54 pm
4 custom slots was a nod to the pioneer gear that has 4 buttons around the filter, so just a short hand to call a specific fx to the colorfx [filter] dial.
geposted Tue 04 May 21 @ 8:26 pm
Very cool, Thank you
I currently have about 20 encoder knobs still looking for work .. trying to do my part to help !
and is
effect_stems_color vocal on
a valid way to apply the colorfx effect, only to vocal (in this case). Does that go in custom button or would it be added with, & effect_stems_color vocal on to the knob mapping? or are either possible?
still unable to get effect_stems_color to do anything. Or is it NOT an audio effect? Still unsure.
and outputs the color "Gray" ??
Still trying to learn.
and is
Nicotux wrote :
test with:
geposted Tue 04 May 21 @ 8:38 pm
OK, was about to ask how to select the effect in such slots
filter_selectcolorfx being unusable
effect_select colorfx being unusable
but what locodog explained (and confirm) is there is only one real slot, and 4 assignable buttons usable as shortcut
geposted Tue 04 May 21 @ 9:11 pm
After Adion explained.. I can get effect_colorfx to work from the example in pic:
and can add all 4 color effect knobs to the Right deck and 4 to the Left Deck.
with the assigned effect in " "
Think maybe better to just use Regular FX, though.
still unable to figure out the effect_stems_color or get it to do anything
And would love to be able to apply stems to the ColorFX, if that is possible.
geposted Tue 04 May 21 @ 10:51 pm
As Nico said, effect_stems_color is just used to get a color for the effect_stems pad button.
As I said, you can use just effect_stems in the way you described and this will also affect color fx
geposted Wed 05 May 21 @ 4:27 am
Thank you so much Nico and Adion and Locodog
I have not been able to get the FX Stems to work on the ColorFX (those controlled by the knobs below the EQs on the default Pro skin)
in this post, Klausmogenen posted a video:
http://www.virtualdj.com/forums/239965/General_Discussion/Is_there_info_about_using_the_new_feature_using_effects_on_individual_stems_.html
and demos the ColorFX at 3:52 min, and was not clear to me that it was working .. I could not get FXStems to affect ColorFX and asked in that thread:
I created this custom button
effect_stems vocal on ? effect_stems vocal off : effect_stems vocal on
to easily turn the vocal FXstems on and off.. It works wonderfully on the standard FX ..
so LOVE IT and use it all the time, so Amazing!!!!
But it does nothing to the ColorFX.. . so that's why have been looking for a way to add to the ColorFX. Would LOVE to also use FXStems separation for ColorFX.
It could be just my install of VDJ that FXStems is NOT working on FXColor.
I can create videos with sound if that would be helpful.
Am I the only one who cannot get FXStems on the ColorFX knobs?
VDJ 6434
Tested with Default Pro skin
Note: I Testwith Loop roll and FXStems Vocal.. since easy to hear that beat is NOT being Loop Rolled.
klausmogensen wrote :
I think it's currently only the regular "old" filter - so not the colorfxs (yet)
But maybe Adion can confirm that?
IIDEEJAYII wrote :
Truly Amazing, once again .... VDJ is the BEST !! Love it !
@klausmogensen
thank you for that quick video test !
I could not get the ColorFX to apply ONLY to a selected Stem, (which you demonstrate at 3:52),
@klausmogensen
VDJ 6434
geposted Wed 05 May 21 @ 7:15 pm
Currently only the filter on the filter knob is applied to individual stems
But you can easily map your own .. . for example
To activate stems FX on vocal & turn on loop roll : effect_stems "vocal" & effect_active "loop roll"
For the color fx slider : effect_colorslider "loop roll" while_pressed
Or just as a "working concept" with a button to turn on the Stems FX for vocal & loop roll turned down
Then a slider to apply loop roll color fx on the vocal only. So its less chance of any "accidents"..
Button : effect_stems "vocal" & effect_active "loop roll" & effect_slider "loop roll" 1 0
Slider: effect_colorslider "loop roll" while_pressed & effect_slider "loop roll" 1 100% while_pressed
geposted Wed 05 May 21 @ 9:40 pm
