Topic: Mute_Stem
Looking for a script I can assign to a button that will mute a stem; even if I load a new song into the deck. I have tried a few times; but it seems when I load a new song it automatically activates all the stems even if I told it to mute the deck while playing the previous track. Thanks in advance.
geposted Tue 04 May 21 @ 10:05 pm
NicotuxHome userMember since 2014
settings -> automation -> resetStemsOnLoad
you can map the mute stem in "ONSONGLOAD" too
geposted Tue 04 May 21 @ 10:18 pm
LIMOLPRO InfinityMember since 2003
you can do this Script,
by pressing once you deactivate the stems, and by pressing a second time you activate the stems in CPU
setting 'mathengine' 'disabled' ? setting 'mathengine' 'cpu' : setting 'mathengine' 'disabled'
geposted Tue 04 May 21 @ 10:44 pm
