Topic: Reassign Flanger to Loop Out
Hello, it's been a while since I've used VDJ! It seems what I'm trying to do should be simple like dragging the desired effect on the pad I want to use. I simply want to change Flanger to the Loop Out effect so when I hit pad3 on my Hercules Starlight, it loops out. Sorry if this was posted already...
geposted Wed 05 May 21 @ 4:15 am
look at the script that calls the flanger and it should be self evident what you need to change.
geposted Wed 05 May 21 @ 9:56 am
