Topic: Mapping Numark Mixtrack Pro FX
Hello, I am planning to buy a Numark Mixtrack Pro FX. Can someone who already owns it send me the mapping script for this specific controller? It's the script that shows what each key does.
Also, anyone knows a tutorial for custom mapping scripting?
Thanks!
geposted Wed 05 May 21 @ 11:02 am
the mapping is built in to vdj already, just go in to mapping and look for it in the drop down controller list.
I did this but I can't find Numark Mixtrack Pro FX in that list.
Maybe someone can help with a .XML file with the full basic mapping?
Thanks
it's in the list,
if it's not in the list then you need to update vdj because even if somebody sent you the mapping file it wouldn't work because the device is not defined in old versions of vdj.
You also need to use latest version of VirtualDJ
Always keep the software up to date. For new features, new controllers, improvements and fixes etc etc thats important..
https://www.virtualdj.com/download/
