Hello everyone,
We accidentally selected 'do not show again' on two splash screens that appear when opening VDJ:
- Do you want to use the controller?
- What layout do you want to use? e.g. stems etc.
How can I get these splash screens to appear when I open VDJ?
Also, how do I get the controller to be used? It is not being recognised to use the faders, knobs, etc. Just the audio.
geposted Thu 06 May 21 @ 8:57 pm
In reality this does not hurt because settings are already available and can be modified at any time
i.e. : for stems use little triangle at center top of equalizer
You can reset any dialog you asked not to show again from settings -> options -> options -> dontShowAgain
geposted Thu 06 May 21 @ 9:15 pm
Try renaming your settings.xml file and everything will reset to new.
What controller is it?
(dontShowAgain in settings to clear out that part, or "reset all" to go to factory settings for everything)
geposted Fri 07 May 21 @ 9:12 am
