I have a Windows 10 gaming PC. Gtx 1070, 16 gigs, and I never had an issue with anything else but launching VDJ as of recent. I DJ every weekend, and a reinstall fixes the prob, but I would like to not keep doing so. Clicking on VDJ just gives me a blue screen with the sad smiley face and force restarts my pc. The stop code I get is either IRQL GT ZERO AT SYSTEM SERVICE or KERNAL SECURITY CHECK FAILED
Maybe its because of Beatport Link cause it started doing this after using it? Or maybe its my interface or the table itself, but unplugging those things don't fix it.
One solution was to update your pc, which I did, and my drivers are up to date too
And yes, I legally bought virtualdj. Has anyone else had this issue, any fixes?
geposted Sun 09 May 21 @ 11:32 am
Sounds like some driver error..
Try update computer, graphic drivers, sound drivers etc
(but you said you already did.. but still its most always a driver error)
Try disconnect hardware like controller and see if same happens etc.
And you can also try rename settings.xml (or delete) in /documents/virualdj/ prior to starting the software to rule out any bad plugins etc
https://windowsreport.com/irql_gt_zero_at_system_service-windows-10/
geposted Sun 09 May 21 @ 11:49 am
