Has anybody realised that the numark mixtrack pro fx pitch sliders are very sensitive. like all i do i tap it a little bit and the BPM changes dramatically. I have my pitch range normally set to either 6% or 8% ,but on my mix track pro 3 the sensitivity was just perfect.
so does anybody know how or if there is a way to adjust the pitch sliders sensivity on the pro fx??
geposted Sun 09 May 21 @ 11:40 am
not sensitive i guess you mean... ?
They might not sensitive enough for ultra fine bpm adjustments on the pitch probably..
Many controllers dont have high definition faders..
You can try set a much higher pitch range, and by that each midi step on the fader will less change
geposted Sun 09 May 21 @ 11:55 am
