Wouldn't it be cool if a groove plugin or drummer could run in sync with the VDJ tracks?
Someone here has successfully integrated a drum machine:
https://www.youtube.com/watch?v=6CxGWx9pLlk
Does anyone have experience with other vst drum plugins as a master effect?
geposted Sun 09 May 21 @ 8:06 pm
Its just a VST effect..
VirtualDJ works with a whole range of VST audio effects, as well as VST instruments
And if you prefer separate apps, or even hardware, often supports Ableton Link that can send sync.
(or midi clock)
(or midi clock)
geposted Sun 09 May 21 @ 8:12 pm
Great! I have a mighty Drummachine standing around in the stable and pawing with the hooves.
It´s Steinbergs Groove Agent, but seems to be incompatible although 64bit...
How to...?
How to...?
geposted Sun 09 May 21 @ 8:25 pm
All might not work, the more advanced ones that are full suits on their own might both be too heavy and overkill
Try some here for example, tested a couple myself, works fine
https://blog.landr.com/free-vst-plugins-drums/
geposted Sun 09 May 21 @ 8:33 pm
One from the link above, just a quick test run for some cheesy drum fun ... ;-)
Was a bit "different" showing a full "real life" drum set ..hehe
geposted Sun 09 May 21 @ 8:39 pm
