Hi,
Finally downloaded 8.5 with the stems and had a question after using. I see you can have the vocal stem as a color fx which effectively adjusts the individual stems based on the way you move the knob.
Is there a way to script vocal stem 100% and all others at 0%, or vocals a 0% and all other stems at 100% with a key stroke? Looking for a quick way to go accapella or instrumental without having to action each stem individually.
geposted Mon 10 May 21 @ 10:38 pm
Just map a keyboard key or custom button to :
only_stem 'vocal'
mute_stem 'vocal'
only_stem 'vocal'
mute_stem 'vocal'
geposted Tue 11 May 21 @ 12:01 am
Brilliant, thanks!
Also, what does the 'bleed' value represent in the pad section?
geposted Tue 11 May 21 @ 12:15 am
The bleed is just how strict the isolation is ..
With 0% bleed its the most "clean" vocal possible, but might also cut some of the natural vocals..
So if you adjust bleed up you get more of the vocals back, but starting to get some bleed from other stems if going all the way to 100%
geposted Tue 11 May 21 @ 12:21 am
