Topic: VirtualDj With Phase on Macbook Pro M1
hello i have question: mwm phase its posible use in macbook pro M1 with VirtualDj ?? ...
I am planning to buy phase but need to know if it will work fine with virtualDj on Macbook M1
thanxs
geposted Wed 12 May 21 @ 3:11 pm
VirtualDJ will work fine .. fully compatible and even native M1 Arm version..
If the Phase (the non hid version) is compatible depends if the driver works on the m1 (and the manager program). As well as the mixer you connect the Phase to.
Not sure about that, but check with the brands website.
