Topic: VDJ PRO FREEZES
I use VDJ Pro as a Radio Presenter and have experienced freezes the past few weeks! I have uninstalled - Reinstalled - Cleaned Up - Restarted!! It still freezes !! Please help
geposted Tue 18 May 21 @ 4:13 pm
Depending on system it looks like some old issues came back ^^
For me this was "somehow worked around" the same way in the past :
Force experimentalSkinEngine to NO
Doing so, skin engine rendering shuts down to 5 or 7 fps, CPU usage being UNSTABLE
then setting experimentalSkinEngine back to yes fixes both problems
Of course usual settings DXVA and safeVideoDecode and useLowPowerGPU and mathEngine and mathEnginePriority can help in other cases ... or not
What is your computer specs ? And using any dj hardware?
And when it freezes is it the software interface, or audio or both ?
And using / doing anything particular when it happens that could be a clue?
If your computer is very low end, you can try set precomputeStems to "only use precomputed" in settings.
