pls help- got a gemini cntrl-2 from a friend- he lost the code or licence that came with the box when he bought it(was lying in storage whole time)....how do i pair or sync it up 2 vdj..or any software for that matter...i dwnloaded atleast 4 programs to try to get it to sync...no luck
thank you in advance
geposted Wed 19 May 21 @ 3:48 pm
Did you try with VirtualDJ?
https://www.virtualdj.com/download/
The controller is supported, so if it doesnt need drivers it should be plug & play ...
If it does need drivers though, these must be installed first
![](/img/336399/56136/gemini.jpg)
geposted Wed 19 May 21 @ 4:38 pm
yes- i have tried installing that version also---so I dnt need that keycode that comes with the controller box?
tnx for assist/
tnx for assist/
geposted Thu 20 May 21 @ 12:40 pm
i have installed it yes..no luck-what am i doing wrong?surely it should be easy plug n play
geposted Thu 20 May 21 @ 12:57 pm
You dont need a key code to start trial and use it (for a while).
But with extended use, you will need a license
Either cheaper Home Plus for home use only (and single controller), or the Pro license without limitations
Do you get a controller detected popup when VirtualDJ starts?
And in VirtualDJ sound settings, is there a Gemini button to select at top?
The controller might need drivers, its a bit old, so couldnt find info right away.. Not listed anymore at Gemini site it seems
A user with same controller and VDJ here,
geposted Thu 20 May 21 @ 12:58 pm
