I recently bought virtual DJ and I can't connect my controller. It is a behringer BCD2000, I see it compatible in the list of controllers but it is impossible for me to use it, however, it is recognized by windows.
How can I use my controller with virtual DJ?
Thanks
Thanks
geposted Tue 25 May 21 @ 5:16 pm
what makes you say its "impossible" ?
What doesnt work?
One common "error" is that the sound card is already taken by Windows, and that prevents the asio from being used in VDJ. But totally depends on what you meant ;-)
What doesnt work?
geposted Tue 25 May 21 @ 6:32 pm
