Topic: Playlist folder selection before saving
when we save a playlist in automix , it places it in the root folder in the playlists folder.
is it possible to have the option to select a different folder inside the playlists folder before saving ?
it would make it easier so we don't have to access afterwards the playlist folder through windows explorer in vdj & drag it where we want to.
thanks in advance
geposted Fri 28 May 21 @ 4:08 am
Not currently...
But might be something to add in future, similar to how Virtual Folders can set parent directory in the dialog popup
thanks a lot !
