so this might be a dumb question, but - if I have two tracks that I know work well together, is there a way to "pair" them? meaning that I will manually set the song pairs, and when I play a certain track that has a pair, VDJ will suggest it.
Is this a thing?
Is this a thing?
geposted Mon 31 May 21 @ 3:18 pm
I made a windows plugin to do just this, it's pending approval from devs.
there's 2 ways this can be done, mark the outgoing track or mark the incoming.
I chose out going, so needed the plugin. [harder to make this way but for me mark the outgoing makes more sense.]
If you use incoming you don't need a plugin
geposted Mon 31 May 21 @ 3:35 pm
would you care to explain? not sure what "marking the incoming/outgoing" actually means.
geposted Mon 31 May 21 @ 5:26 pm
The info has to be saved somewhere right, I use the grouping tag.
If you discover when playing track "A.mp3" that track "B.mp3" works well as a follow up then mark the first track [out going] with the name of the second track [in coming]
At a later date when you're playing track "A.mp3" again, a button will read that tag and give you your reminder list.
http://www.virtualdj.com/forums/241324/General_Discussion/Track__linking__windows_plugin.html
geposted Mon 31 May 21 @ 5:42 pm
