I Neither can't broadcast nor make a podcast on vdj's servers. I have whitlisted and checked hosts file too. Any possibilites to fix this??? Thanks.
geposted Wed 02 Jun 21 @ 3:11 pm
If you can not even podcast, try this tool:
For PC:
https://drive.google.com/file/d/0B379w5vt4TjjeG1BQXcyV2JySkk/view?usp=sharing
For Mac:
https://drive.google.com/file/d/171R7CO6pB7n5-zE8Up-H-e2R9FFHswki/view?usp=sharing
For PC:
For Mac:
geposted Wed 02 Jun 21 @ 4:12 pm
It says "hosts file not changed"
geposted Thu 03 Jun 21 @ 6:46 pm
check your firewall, if you have blocked VirtualDJ outgoing.
To padcast the software needs access to the servers to be able to upload
geposted Thu 03 Jun 21 @ 7:38 pm
I checked. How must be the settings??
geposted Thu 03 Jun 21 @ 7:43 pm
Your computer might not allow the software to connect properly.
To fix that you would have to look at the Windows firewall settings. Most likely place.
(its not a VirtualDJ setting though... )
See if there are several entries of VirtualD in firewall, maybe you only allowed older 32-bit version or something like that :
https://pureinfotech.com/allow-apps-firewall-windows-10/
Other than that, perhaps your router settings preventing a VirtualDJ connection. But seems unlikely, its just a normal connection, nothing too special about it.. .
geposted Thu 03 Jun 21 @ 7:48 pm
I did it but, nothing happened...
geposted Thu 03 Jun 21 @ 8:09 pm
Not sure then, can always contact Support Team, and ask if anyone can take a remote look:
https://www.virtualdj.com/help/
geposted Thu 03 Jun 21 @ 8:10 pm
UPDATE: Broadcast seems to work, but my devices can't play ir. I think the port is not open...
geposted Sat 11 Sep 21 @ 9:44 pm
