Hi
I have a Hercules 500 which has a "Assistant button" which I have mapped to load tracks into automix.
Simple question please:- Whats the script to give this button a colour led.
I just want the assistant button to stay ON CONSTANTLY...and any colour will be fine
So in LED ASSISTANT in the mapping,,,Simply what should I type in the action so that it glows constantly.?
Thanks
Thanks
geposted Wed 02 Jun 21 @ 4:35 pm
CURRENTLY THE ASSISTANT BUTTON DOES THIS:
automix_add_next and this works fine.
What "exactly" should I type (after the above) so that the LED glows a constant colour all the time?
automix_add_next ( Then exactly what?)
Thanks
Thanks
geposted Wed 02 Jun 21 @ 4:40 pm
OR..should I go to LED_ASSISTANT in mapping and type something in their instead...if so What?
geposted Wed 02 Jun 21 @ 4:42 pm
try just use the action : ON
for the LED_ASSISTAN
geposted Wed 02 Jun 21 @ 4:44 pm
Well that was easy...Thank you for your help.... I tried everything...ON does the trick!
cheers
cheers
geposted Wed 02 Jun 21 @ 5:56 pm
