the headphones settings are mess up every serato controller i use with virtual dj is messing up
geposted Wed 02 Jun 21 @ 4:47 pm
define "messed up"... whats not working or how is it working?
auto selecting deck? or hearing master instead of cue channel?
totally depends on what you mean, what the way would be to make it as you want
geposted Wed 02 Jun 21 @ 4:49 pm
Trying to cue on my ddj sx3 with my headphones. No prefade listen while one track is playing. how di I fix that?
geposted Thu 03 Jun 21 @ 12:52 pm
On the DDJ-SX3 you select what channel to hear in the headphone at the channel CUE buttons at mixer section. https://www.virtualdj.com/manuals/hardware/pioneer/ddjsx3/layout/mixer.html (#4)
Additionally you have headphone level knob, and headphone mix knob at front of the mixer
The headphone mix knob adjusts the blend between master and cue channel
https://www.virtualdj.com/manuals/hardware/pioneer/ddjsx3/layout/frontrear.html (#61 & #62)
For it to work as it should, you need correct audio settings, see bottom of page here:
https://www.virtualdj.com/manuals/hardware/pioneer/ddjsx3/setup.html
Simply click the DDJ-SX3 button in sound settings
geposted Thu 03 Jun 21 @ 1:05 pm
