Bring back the normal scratch !!! Like in build 5609.
next versions - stupid JogSenstivityScratch! smudged sensor
geposted Thu 03 Jun 21 @ 12:22 pm
sounds like you might have a less than ideal controller for scratching perhaps?
No need to use jogwheel sensitivity...
And if you are serious about scratching, a controller with touch sensitive jogs is the way to go.
geposted Thu 03 Jun 21 @ 12:32 pm
on version 5609, everything is fine. Also, the mouse feels the difference
geposted Thu 03 Jun 21 @ 1:17 pm
add a selection of the scratch algorithm
geposted Mon 07 Jun 21 @ 3:46 am
I don't think people understand what you are talking about
Are you actually scratching? Like using a turntable in a DVS setup, or a good quality touch sensitive platter controller?
Or are you using your mouse?
Or are you using the Scratch DNA feature?
Or are you using the "scratch" action script on a keyboard key?
Or are you triggering samples with scratch sounds?
And what is the smudge thing you are talking about?
And what is "normal scratch" to you?
And after that is clear - what do you think has changed?
geposted Mon 07 Jun 21 @ 8:17 am
Testing on Mouse and Mixtrack Pro.
in 5609 accurate sensor, in future versions - smeared. This is view like in mouse cursor, like and controller,
especially at low speeds
geposted Mon 07 Jun 21 @ 11:07 am
Are you referring to how the horizontal waveform now [...now, lol, this update is over a year old...] only works as CD style nudge when grabbed & playing.
That's the only difference I can see||hear.
geposted Mon 07 Jun 21 @ 11:36 am
Oh, are you talking about grabbing the top wave file with your mouse, trying to scratch?
If so, you'll have to forgive us - that is so far from what scratching normally is, that no one understood what you meant
Yes, that won't work in VDJ2021 by default, because it's set to another waveform type to illustrate stems separation. You can get it to work by selecting the "beat" wave form under layout
You can also disable stems, to get out of the new realm of waveforms
But a better idea is to use the vertical scratch waveforms instead - like shown in this video
geposted Mon 07 Jun 21 @ 12:08 pm
