i would like to add a custom logo to where the yellow bar is on the broadcast skin but cant seem to figure out how to do it
any ideas?
geposted Thu 10 Jun 21 @ 12:00 am
Make the image full screen (1920x1080 pixels) with transparent background.
And place the logo at the image where you want it ...
Then use this image as videoLogoImage in settings
And set videoLogoSize to 1
geposted Thu 10 Jun 21 @ 6:10 am
Easy way to create, if unfamiliar with photo editors :
1) Open https://www.photopea.com/
2) Choose "File=>New" and set pixel size with transparent background and click "Create"
3) Drag in your logo and place and size where you want it
4) File=> Export as PNG
Thats it ;-)
Thats it ;-)
geposted Thu 10 Jun 21 @ 6:28 am
Thanks will give it a go
geposted Thu 10 Jun 21 @ 7:11 am
Thanks Rune, Much appreciated
geposted Thu 10 Jun 21 @ 7:38 am
