Purchased the Tractor Control S4 recommended in a list of controllers in VDJ only to find out its mapped for the basics only? What the hell????
geposted Sat 12 Jun 21 @ 3:33 am
Edit ... more info below.
geposted Sat 12 Jun 21 @ 3:46 am
@kradcliffe s4 mk3
@PtownDJ
Nowhere does it say that the S4 mk3 is officially supported by vdj, atomix made every effort to cover it but native instruments hasn't shared any information on the NHL protocol that this unit uses for screens.
@PtownDJ
geposted Sat 12 Jun 21 @ 3:49 am
Native Instruments haptic and screens being proprietary is currently not supported.
But other than that it works..
See here:
https://www.virtualdj.com/forums/227958/addons/Traktor_Kontrol_S4_MK3.html?page=1
geposted Sat 12 Jun 21 @ 1:06 pm
Yes, Native Instruments has blocked the screen and haptic usages for other software
So yes I totally agree with you:
What the hell is Native Instruments doing????
I would 100% send it back with a written complaint to Native Instruments
I'm also pretty sure what they are doing is illegal in the EU - but maybe not in the US (customers are generally better protected under EU law)
geposted Sat 12 Jun 21 @ 1:20 pm
With all given respect....the marketing strategy of Native Instruments is known. THe grade of compatibility with VDJ is as well known.
It makes absolutley no sense at all to purchase Native instruments hardware if you are not planning to use Traktor.
For the called prices twice not.
Pioneer or Denon or whatever would have been a smarter choice for the use with VDJ.
geposted Sat 12 Jun 21 @ 2:07 pm
It's actually worse than most understand, some of their [NI] gear out of the factory works differently depending on the batch number, them knowing the firmware, they can make the driver make it work with traktor.
here's hoping when midi 2.0 standard goes mainstream these propriety shenanigans will be laid to rest, doubt it though.
geposted Sat 12 Jun 21 @ 2:23 pm
I really like the look of some of the NI hardware, but the software is truly awful.
Each to their own and all that .......
geposted Sat 12 Jun 21 @ 2:44 pm
Ive scheduled the return, reason being that the controller has no NI support for VDJ... What do you guys think about the "Rane One"?
geposted Sat 12 Jun 21 @ 2:53 pm
Seems pretty decent. Expensive for a 2 channel controller though. Also the motorized platters take a bit of getting used to.
https://www.virtualdj.com/products/hardware.html?model=rnone
https://www.virtualdj.com/manuals/hardware/rane/one/setup.html
geposted Sat 12 Jun 21 @ 2:56 pm
kradcliffe wrote :
I really like the look of some of the NI hardware.
looks good but servicing consumables, like a knackered fader, are terrible;
1 NI don't hold replacements [and won't tell you where you can get them]
I found who makes them and they are cheap as chips but you need to navigate about 20 or so spec sheets to find the right fader & order 10
2 actually replacing, replacing faders should be a single screwdriver 20 minute job, not with NI, heatgun + solvents to remove the cover plate [cover plate needs all mixer pot nuts to be removed], pretty much break the unit into boards, and then the faders are soldered to the pcb, even with all the toys it's a 2 hour job
As a service tech, I have lots of cursing for NI HW
geposted Sat 12 Jun 21 @ 3:40 pm
I purchasesd a new controller and this weekend was my first time using it live... I will say that a developer who works foe NI was very impressed,,, I mentioned I had just returned there controller due to no support.... I don't get it, VDJ is stable, that's all that matter to me, Serato works much the same way, nut not always! Im not sure what to do, I love the sound of the RANE One, But all these bells and whistles really are ofer the top for was that average DJ needs., Im so tired I hope this makes sense.... I would love to hear back from the VDJ environment...n est of luck toyoiv
geposted Wed 23 Jun 21 @ 6:46 am
