Hello. I have a Denon MC6000 Mk2 and I'm running virtual 2021. Everything works great except I would like to have volume control of my sampler from the mixer. Is there any way to set either channel 3 or 4 to play the sampler out?
geposted Fri 18 Jun 21 @ 4:14 pm
Can do that in software, click the small dot at upper right corner in sampler in sideview.
And there you can set auto routing to deck 3 or 4
![](/img/338188/89135/sampler routing.jpg)
geposted Fri 18 Jun 21 @ 4:19 pm
