Is there a way to automatically play saved loops once the track has reached the start point of the (next) loop?
    geposted Fri 18 Jun 21 @ 6:27 pm
          Found it!  "saved_loop_prepare x" (What a great product VDJ is!)
    geposted Fri 18 Jun 21 @ 6:50 pm
          Yes in deed is a great software. I use the prepare script quite often. Also if I'm always going to loop a song  in the same spot, I add a hot cue then in the POI change it's type to Action and add the "Loop X" script, where X is the amount of Beats you wanna loop, and change the marker to blue. To me blue means an automatic loop.
       geposted Tue 22 Jun 21 @ 9:02 pm
