se me ha actualizado el virtual dj 8 a la version 21.
tengo una mesa hercules djcontrol instinct p8 y ha dejado de funcionar.
sera problema de compatibilidad?
espero que me deis alguna solucion gracias
geposted Mon 21 Jun 21 @ 9:17 am
Should work same way..
Did you perhaps change computer or update windows/mac also?
If so, you need to install drivers likely
https://www.virtualdj.com/manuals/hardware/hercules/p8/setup.html
geposted Mon 21 Jun 21 @ 12:11 pm
