Topic: Setting Up New Laptop Using VMS4.1
Hi, well it has been a long while since I set up a new laptop (Windows 10), and that together with the VDJ2021 seeming different to past versions I am struggling to know where to start. Is there a guide that I can be directed to? Or can someone please list out the steps needed? Thank you.
geposted Tue 22 Jun 21 @ 1:49 pm
geposted Tue 22 Jun 21 @ 1:53 pm
So I have downloaded the ASIO drive no problem but when opening VDJ (connected to the VMS 4.1) I am still prompted to download "up to date" drivers. The VMS 4.1 works just fine. Is it the firmware I am supposed to update also? When following the script to update firmware I am not getting the same prompts as the script suggests. If the VMS4.1 works fine do I need to update firmware?
geposted Tue 22 Jun 21 @ 3:15 pm
