Hi,
Is there a way to edit the 'Type' tag. I can't see it in the Tag Editor.
Some of my karaoke files have imported as audio and I want them to show as karaoke.
I'm not sure how long it has been like this, but would like to fix it.
Any help would be appreciated.
geposted Sat 26 Jun 21 @ 2:34 pm
There is a small check box for karaoke bottom right of tag editor, but for Video files only
you can "video edit" and add lyrics(or not) to get a karaoke version - edited vdjedit version of the file
geposted Sat 26 Jun 21 @ 3:01 pm
It seems strange, all the karaoke files are zipped mp3+g. I can't seem to find an obvious difference between the ones that show as audio and the ones that correctly show as karaoke. Any ideas?
geposted Sat 26 Jun 21 @ 3:17 pm
The cdg itself must show as karaoke
Zipped mp3+g or ogg+g appear as karaoke when both audio file and CDG have the same name
If manually deselected they must appear as video
But zipped using zip64 method are not usable (VDJ do not want to decompress them, even delegating to external/system for "legal" reasons) and default to audio (but do not play, with error)
When names differ the audio track in zip file appear as audio too
if cdg was added as a supported file format, it used to appear as video (not tested recently) but they are not linked
geposted Sat 26 Jun 21 @ 3:54 pm
