Hello!
Is there a way to script the VDJ database backup function to run weekly, or on some automated trigger? I'd like to keep things backed up, and while I have OneDrive and BackBlaze they are syncing only the last 30 days (backblaze) or not at all, and they are quick to update and overwrite.
I'd love to be able to know that an automatic function is creating the backups that then the offsite services can store.
Is this possible? (Hopefully my question makes sense.)
Stay safe and cheers for any help.
slumbdog
slumbdog
geposted Sun 27 Jun 21 @ 9:28 pm
Unfortunately there's no action that you can use to backup the database.
Otherwise it would be possible to use Event Scheduler to automate the backup procedure.
geposted Mon 28 Jun 21 @ 11:44 am
If you really want to, you can run a BATCH file to copy the DATABASEs every time you TURN ON your system (this would be AUTOMATIC).
Or create a shortcut/batch file and execute it manually when you insert a USB STICK/SD CARD (this is what I do) then execute VDJ program.
Many ways you can achieve it without using VDJ built in DATABASE backup.
geposted Tue 29 Jun 21 @ 6:40 pm
You can use Windows' built-in Task Scheduler to make a copy:
https://active-directory-wp.com/docs/Usage/How_to_add_a_cron_job_on_Windows/Scheduled_tasks_and_cron_jobs_on_Windows/
Even better, you can set up Git for Windows with the task scheduler and then you can revert the database to any previous backup.
https://gitforwindows.org/
geposted Tue 29 Jun 21 @ 7:11 pm
Irrespective it would be easy for Adion to add an option for a once a month automatic backup. They take up little space and would save a lot of hassle for people who overwrite or lose the contents of their VDJ folder.
geposted Tue 29 Jun 21 @ 7:41 pm
