can someone help me please i have some put my Skin in to a touch skin thing and it's to big on my desktop screen and i don't know how to fix it
geposted Fri 02 Jul 21 @ 12:19 am
You can delete/rename settings.xml in /documents/virtualdj/ before you start VirtualDJ to have default again.
OR, delete the skin that doesnt fit well in /documents/virutaldj/skins/
Although most skins should be able to resize to your screen.
geposted Fri 02 Jul 21 @ 11:50 am
oh ok thank you I'll see what I can do with this if worse case i can just do a full uninstalll and re download and install the software again
geposted Fri 02 Jul 21 @ 1:36 pm
